Is it possible to use a 98 GT alternator on a 99 GT - MustangForums.com
Old 07-25-2013, 07:07 PM   #1
Gluck Hunter
Default Is it possible to use a 98 GT alternator on a 99 GT
Is it possible to install a 98 GT alternator on a 99 GT? All the heavy duty high heat resistant/high output alternators are made for 98 and earlier Mustangs or 05 and up. All the 99-04 "high" output alternators are pretty much the same using the same materials as the OEM one and aren't that much stronger. My engine creates a lot of heat especially in the TX heat (sometimes 110+ degrees) and these so-called 99-04 PA performance alternators are pretty garbage under a full load of 3000 watts worth of music, lights, and a/c. We all know alternators suck in the heat but I see some really high speed made ones for about 600 bucks that claim to output 250-300 amps and resist high temps. Unfortunately they're made for every Ford vehicle but the 99-04 mustang...
Gluck Hunter is offline   Reply With Quote
Old 07-26-2013, 02:28 PM   #2
Z28KLR
Z28KLR's Avatar
Dunno... One of my tactics that usually gives good indication is to look up the part somewhere and compare part numbers between the two different vehicles. If the part number is the same between the two, then you should be ok to do it. If the same part carries different part numbers then they likely will not interchange.
Z28KLR is offline   Reply With Quote
HELP! P340 p344 and is not the alternator! Golfsito GT S197 General Discussion 9 10-06-2015 12:02 PM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
4.6L Supercharger MasterLanMan Pipes, Boost & Juice 19 09-26-2015 11:03 AM
Will not fire up Wombatnation 5.0L (1979-1995) Mustang 12 09-13-2015 10:16 PM
alternator. so hot will burn your hand on 2004 3.9 v6 mrmrultimate Texas Regional Chapter 2 09-10-2015 10:43 AM
