How to replace check engine light/remove gauge cluster
Either it is burnt out or removed by PO. I am replacing the speedo/odometer gears this weekend and will have the gauge cluster removed, and checking to see how to replace this light.
All u gotta do is take off headight ****, the two 8mm bolts that hold the trim peoce in p
Place the pop that off and remove the gauge cluster bolts slide it out a little then unplug it
