Cat stutters when accelerating?
Been having a problem with my car and upon further review I've decided that my car stutters and hesitates when accelerating (before I thought it was trans related)
What happens is I'll be accelerating and then all of a sudden you will feel the acceleration stop. Imagine you are watching the tachometer, the RPMs are increasing linear as you keep your foot in the same position, then the car hicups and the rpms stop increasing, then back to normal.
You know when you let the clutch up quick and the car gets a little jerky, it's just like that.
Recent things I changed to my car:
Lucas ethanol treatment (Friend had an extra bottle, figured why not)
IAC valve restriction plate (re-used the old gasket, might have a leak there?)
Oil change, castrol synthetic
Thermostat, Coolant temp sensor
I had my battery unplugged for a long time doing some car audio stuff, maybe the computer is relearning stuff still?
I'm leaning towards spark plugs or the coils. What do you guy's use for spark plugs? Any that come pre-gapped?
Does it go me, meo, me, meo, meow? Sorry couldn't resist.
It kinda sounds like a misfire under load. Check the usual stuff. Spark plugs, coils, coil boots. Any codes? Also for spark plugs NGK all day.
What do we gap them at now-a-days? I know we never stick with the stock gap lol.
Replaced the boots and coils on the COPs with some parts from duralast and got some NGK iridium plugs. Still have the issue but my car idles much nicer.
I had the fuel filter changed about a month ago but the fuel pump... maybe. Wouldnt a bad pump fail to deliver fuel when I'm flooring it in a low gear? I can floor it through the gears without an issue, just when accelerating in a high gear I get a hic-up. And no, I'm not talking about goosing it in 5th gear at 30 mph Just a 1/2 throttle pull in 4th at 40 will do it.
I'm gonna check for vacuum leaks tomorrow when it's light out. Tonight when I was at a red light I heard a high pitched leak sound. Possible, since I just did some work on the IAC valve right?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
Offendant
09-23-2015 07:21 PM
stangin1996gt
09-21-2015 11:01 AM
