Yeah, it sounds like either a bad caliper or a collapsed/crimped soft or hard brake line. I have seen rubber lines collapsing internally, although it was on really old lines that had been abused. It could also be crimped/bent/damaged hard brake lines. Just follow the line up from the caliper to the master cylinder. If you see it is bent/damaged/crimped then it needs to be replaced.
You can try bleeding just the one wheel if your lucky it will work. Chances are youll need to bleed all four, starting from the furthest wheel from the master cylinder and then the next furthest. So rear right , rear left, front right , front left.
Well I got it all back together and bled them, and its still sticking. Not as bad but it sticks and the brakes were really hot compared to the rest. Caliper I guess?
Money is tight at the moment, so could I get by with replacing this one caliper? Or do I have to do both? The one is fine and looked fine when I pulled it yesterday
