lcd freeplay correction kit
Old 10-31-2013, 04:41 PM
jgordon
jgordon's Avatar
Default lcd freeplay correction kit
i just installed the lcd freeplay kit,the spring fits a little sloppy
likes its a little too long,would that mean the cable is adjusted
a little too tight? thanks in advance
jgordon is offline
Old 11-05-2013, 04:30 PM
jgordon
jgordon's Avatar
that would be the ldc freeplay correction kit,the spring is a little too long
and slides near the edge of the coupling,is the fork not going back far enough?
jgordon is offline
Old 11-08-2013, 03:16 PM
jgordon
jgordon's Avatar
hello,anyone out there?
jgordon is offline
Old 11-08-2013, 04:06 PM
Stevo86
Stevo86's Avatar
We're all here I think everyone just assumed you meant liquid crystal display freeplay correction kit and said "huh, I have no idea what that is."
So if you would please clarify your question, maybe we can help.
Stevo86 is offline
Old 11-09-2013, 03:52 AM
petrock
petrock's Avatar
Pictures would help too...
petrock is offline
Old 11-09-2013, 04:20 AM
dawson1112
dawson1112's Avatar
Did you install this correctly? If I am understanding you correctly this is what you installed to take the dead spot out of the top of the clutch pedal? It should fit like the pic below.
dawson1112 is offline
Old 11-09-2013, 09:58 AM
jgordon
jgordon's Avatar
yes that is the spring i installed,i just went over my install and found out
i had the clutch cable adjusted too tight,i gave more slack in the cable,
now it looks like in the picture,thanks
jgordon is offline
Old 11-14-2013, 02:20 PM
Lackey'sGT
Lackey'sGT's Avatar
Do you guys suggest using this to keep the throw out bearing off the pressure plate, because I was tempted to make one but I heard the throw out bearing was suppose to touch the pressure plate with a little preload.
Lackey'sGT is offline
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: lcd freeplay correction kit
