Head Gasket question.
Old 11-21-2013, 10:08 PM
nathansmith50
nathansmith50's Avatar
Angry Head Gasket question.
I've read that the 4.6 head gaskets can be reused. Is this the case?
also are the valves from the NPI heads the same as the PI heads?
Here's my reason.
The heads are torqued onto the car it's timed and i start turning it only to hear a loud snap. i turn it again to see that it's a valve sticking...i feel around and it's definitely bent.
So obviously i have to take the head back off the car. but I've also obviously never fired it.
nathansmith50 is offline
Old 11-21-2013, 10:32 PM
71_340
71_340's Avatar
Two things:
1. Your valve timing was not correct!
2. I would never reuse a head gasket, to much work to replace it should it leak.
Next time when you think that you have your engine "timed" turn it over by hand, don't force anything, and make sure your marks are lined up after turning it over several times.
71_340 is offline
Old 11-22-2013, 07:28 AM
nathansmith50
no the timing was correct. i knocked a rocker arm askew when torquing the cam in and didn't notice so when i turned the motor over it bent the valve.
Old 11-22-2013, 07:57 AM
Stevo86
Stevo86's Avatar
The follower held the valve open?
Some head gaskets are can be re-used but I've really only ever seen it done in high performance applications where you're in the pits and gotta re-use the gasket if you wanna make the next round. For a daily driver I would definitely just get another set.
Stevo86 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Head Gasket question.
