Key Stuck in ignition
I just finished replacing my heater core, got it all buttoned back up and started it checking for leaks and everything. Turn the car off and realize that my key issnt going all the way back so i cannot take the key out. It is in automatic and i verified its seeing park cause i cannot put it in drive and start it. Any ideas that dont involve taking the whole dash back off?
Thanks
Thanks
Just finished and had the same problem. Drop the steering column down and there's a linkage on top of it for the interlock that has two small torx bit screws. Pull that off, turn key to lock position then reinstall and you are all good!
Now to get rid of that blasted anti-freeze smell in the car...
lincolnshibuya
12-08-2015 04:37 PM
bradleyb
11-27-2015 07:50 PM
logan409
09-26-2015 07:43 PM
