Does AnyoneHave Any Experience with...
Old 12-28-2013, 02:32 PM
TXMach
TXMach's Avatar
Default Does AnyoneHave Any Experience with...
...mating a BBK Twin-65mm throttle body with the JLT Performance Next Generation Ram Air Intake? (03-04 Mach 1)
I ask because I ran into an issue with using that particular throttle body with my stock intake tube. The "mouth" of the throttle body is too long and the stock intake tube is too shallow before the TB hits the inner lip of the tube. This resulted in not being able to clamp properly, subsequently causing a massive vacuum leak. So now I'm looking for an intake tube that will fit with that particular BBK throttle body.
It seems JLT knows a bit about what they are doing so I'd like to go with it. Not that I'll see much, if any gains from this intake, but at least it might work with the TB.
TXMach is offline
guitarman376
10-11-2015 01:47 AM
tmdm
09-17-2015 08:51 PM
rksnow1
09-14-2015 08:46 PM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Does AnyoneHave Any Experience with...
