Differential question??
Old 12-29-2013, 08:44 PM
thatdude305
thatdude305's Avatar
Default Differential question??
My differential was checked and they said I had metal shavings? They said all I need to do is change the fluid. Anybody ever come across this same issue?
thatdude305 is offline
Old 12-30-2013, 07:32 AM
Stevo86
Stevo86's Avatar
Depends on how much metal and how big the shavings were. A little bit is ok, big fat chunks and it's probably time for new gears and bearings.
Stevo86 is offline
Old 12-30-2013, 06:20 PM
uberstang1
Chupacabra
uberstang1's Avatar
+1 depends on how much metals in there, rear end is pretty basic you have a carrier, carrier bearings, pinion bearing, a pinion gear and a ring gear, little shaving is common with mileage as u have two gears constantly contacting eachother, if the metal is from a bearing well obviously that is bad.
uberstang1 is offline
Old 12-31-2013, 11:28 AM
WJL
WJL's Avatar
A little or a lot of metal is not good, i think you can get a magnetized plug which will collect some of the shavings, this is not the end of the world just start planning on some new 3:73's or 4:10's
WJL is offline
Old 12-31-2013, 11:30 AM
TXMach
TXMach's Avatar
I wouldn't worry too much on that unless you hear a "whirring" sound from back there. Uber and Stevo are correct, tiny glitterish FLAKES are normal. Tiny PEBBLES are not.
TXMach is offline
Old 01-01-2014, 10:47 AM
WJL
WJL's Avatar
Metal shavings in your differential, no that's not a problem, "REALLY" it's just an indication something is wearing or is wore out.
Wait here's some more good advise "Drive it until it breaks then you'll know what to fix" the towing bill only add a "C" or so to the repair bill.
If it were up to me i would remove the cover, drain the gear oil, inspect the inside to see if you can see where it is coming from, you can also check backlash at that point, you also want to make sure what you are seeing is not just clutch pack material. if you don't have the experience to do this, I would suggest finding a local guy/shop not a quick change oil store.
The guys are right the rear end is more than likely not going to fallout tomorrow but there is a pending concern which i think you would be better off to start now and plan your repair rather than to take the wait and see what happens approach.
Not looking to argue, Just saying
WJL is offline
Old 01-01-2014, 04:30 PM
uberstang1
Chupacabra
uberstang1's Avatar
There hasn't been a single gear oil change on any type of vehicle I've done that didn't have some sort of metal flake in the old oil.
Old 01-01-2014, 05:32 PM
reldla1996
reldla1996's Avatar
I liked TXMach's "glitterish flakes" description, it's a good one for what you normally see.
reldla1996 is offline
Old 01-02-2014, 08:32 AM
WJL
WJL's Avatar
Just to clarify, He said metal shavings.
There is a big difference between Clutch material, which is somewhat expected and acceptable to a point and "metal shavings"
WJL is offline
Old 01-02-2014, 08:54 AM
JeffBall
JeffBall's Avatar
WJL, were talking differential here...why would he have clutch material in his diff?
JeffBall is offline
Quick Reply: Differential question??
