Traction Control Issues
Old 01-06-2014, 01:08 PM
CobraClone_WV
CobraClone_WV's Avatar
Default Traction Control Issues
I have a 2002 Mustang GT. After replacing the stock intake manifold with an aftermarket typhoon intake manifold the traction control will not turn on. I am about to purchase the diablosport predator tuner, which has a switch that you can turn the trac control on and off. Will it still turn it on with this intake? Has anyone else had this problem?
CobraClone_WV is offline
Old 01-06-2014, 03:27 PM
JeffBall
JeffBall's Avatar
Tracton Control has NOTHING to do with your intake. The traction control Module is below your air filter (Kind of, inside the engine bay near radiator), maybe you knocked a wire loose or something while messing with the intake? And are you saying the traction control wont turn on? As in, it will just keep spinning? or you cant turn it off, so that you can keep spinning?
JeffBall is offline
Old 01-06-2014, 05:21 PM
CobraClone_WV
The traction control stays off so it spins alot on take off instead of gripping the road.
Old 01-06-2014, 10:10 PM
JeffBall
JeffBall's Avatar
Soo.... On your button in your console, is the light on, or off? And traction control doesn't magically make you grip the road, it simply reduces power (mainly through spark and fuel) ONCE the tires start to spin.
JeffBall is offline
LivingInThePast
09-16-2015 12:20 PM
FivePointToTheOh
09-14-2015 03:35 PM
09-08-2015 11:50 AM
iculookin
09-02-2015 12:34 PM
Quick Reply: Traction Control Issues
