1998 Manual Trans speedometer questions
Old 01-09-2014, 06:01 PM
foxtrot
foxtrot's Avatar
Default 1998 Manual Trans speedometer questions
I have the cable type of speedometer in my 1998, I guess the cut off was 1998 as the 1999 speedo is electronic and can be corrected using a chip. Changed rear gears and the 4:10 is way off. Wondering if it will throw anything else off??
Question:
For a 1998 cable speedo set up and manual trans what is the speed information used for in the ECU?
I am betting nothing.
foxtrot is offline
Old 01-09-2014, 08:59 PM
TXMach
TXMach's Avatar
If the speedo is off so is the odo. I don't think it throws anything else off. You'll need a speedo gear.
http://search.americanmuscle.com/sea...=mustangtuning
TXMach is offline
Old 01-15-2014, 02:54 PM
foxtrot
foxtrot's Avatar
Yes I have the 23 tooth speedo gear for the 4:10 in it right now but the speedometer readings are still off. It shows I am going 10-20 MPH faster than I am really going. And yes I am racking up miles that are not real.
The question was if the speed is not right does it matter to the engine ECU/IAC control etc? The car runs really good after all the work I put in it. Actually better than when I first purchased the car. So I am guessing that its not inputting any signal not the ECU. Would just be noce to know for sure.
foxtrot is offline
Old 01-16-2014, 01:07 AM
TXMach
TXMach's Avatar
I wish I had an answer for you. Anyone else wanna chime in?
TXMach is offline
Old 01-25-2014, 12:47 PM
LilRoush
LilRoush's Avatar
What size tires are you running?
LilRoush is offline
articman
06-21-2018 11:45 PM
97SN95GT
09-13-2015 09:45 PM
Mustangmalo
09-06-2015 05:22 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: 1998 Manual Trans speedometer questions
