04 GT bouncing idle. I've tried all I know to do, and now I'm reaching out.
Old 01-18-2014, 03:27 AM
prlj91
prlj91's Avatar
Default 04 GT bouncing idle. I've tried all I know to do, and now I'm reaching out.
Like the title says, my GT's idle bounces back and forth when in park, and also while in gear stopped at a stop light. Here's a video I uploaded to help you see what I'm talking about
(please ignore the oil pressure reading, as I have a malfunctioning sending unit)
It doesn't bounce much, as you can see in the video, but it's enough to be really annoying, and it's not supposed to happen. I don't notice any loss in performance or trouble driving, and it never dips low enough to die or make the engine shudder.
I've tried everything. I cleaned the MAF, IAC, sprayed almost a full can of brake cleaner around all the vacuum lines hoping to maybe uncover a vacuum leak. I've changed the fuel filter, run endless gallons of injector cleaner, but nothing. There are no codes or anything popping up. It does it regardless of outside temp, and engine temp, though it is a little worse when the engine is up to temp rather than cold. It does it regardless of the AC being on or off, and I'm at my wits end.
All that being said, anyone have a clue what it could be?
prlj91 is offline
Old 01-18-2014, 11:54 AM
8111870a
8111870a's Avatar
Change the IAC motor. Cleaning doesnt always work, when it does its usually a temporary fix.
Use OEM part.
8111870a is offline
Old 01-18-2014, 06:54 PM
prlj91
prlj91's Avatar
I'll try that too, whenever I get the chance.
prlj91 is offline
Old 01-18-2014, 08:19 PM
Stevo86
Stevo86's Avatar
How old are the 02 sensors. As they wear out they begin to switch slowly which leads to bigger swings in fuel so you can get kind of a surging effect.
They also start to fail lean by virtue of how they work which means you may already be running a little fat if they're old.
Stevo86 is offline
Old 01-18-2014, 11:49 PM
Thatsweetstang
Thatsweetstang's Avatar
I'm leaning towards IAC, I've never successfully cleaned an iac and all was well. They crap out a lot. I would put a new one in, unplug the battery for a bit, then fire it up and see what happens. If you don't have any vacuum leaks I would start with a new IAC.
Thatsweetstang is offline
Old 01-19-2014, 07:44 AM
tadpole1969
tadpole1969's Avatar
get a new IAC and problem solved
tadpole1969 is offline
Old 01-21-2014, 12:08 AM
prlj91
prlj91's Avatar
The O2 sensors are as old as the car, so maybe that's what's up. Lots of people say replace the IAC, so when I've got a spare Franklin sitting around, I'll go do that.
prlj91 is offline
Old 01-21-2014, 08:23 AM
Stevo86
Stevo86's Avatar
The only real function of the IAC is to hold the RPM after you let off the throttle and to allow extra air flow for the A/C and cold start. The base idle adjustment is still at the throttle plate which is why you sometimes need to adjust the aftermarket ones to get the car just right. You just use the IAC to tweak it.
If you want to check just unplug it, the car should stay running. If the idle smooths out you've found your culprit.
Stevo86 is offline
Old 01-21-2014, 09:58 AM
prlj91
prlj91's Avatar
Just did it twice. The car dies when I unplug the IAC.
prlj91 is offline
Old 01-21-2014, 03:46 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The PCM's control of the IAC (and of ignition timing) have everything to do with the engine's idle speed, under all conditions--with proper adjustment of the throttle stop screw (not an idle adjustment in the classic sense)--being a critical part of the overall system.
Properly set the stop screw keeps the throttle cracked open just a bit to allow a small amount of air, insufficient to idle the engine, to bypass the throttle valve. The PCM then commands the IAC, by sending it a variable duty cycle square wave signal, to open enough to provide the additional air needed for the engine to idle. At a normal hot idle the IAC is held about 35% to 45% open by the PCM--here is what that signal looks like:
Because of this unplugging the IAC, causing it to close, with the engine idling and hot should cause the rpms drop or even cause the engine to stall.
If a higher/more powerful idle is needed the PCM opens the IAC a bit more, it can also close the IAC a bit if the idle is too high--it does this continuously and dynamically to keep the idle at the speed set in the tune. Adjusting the throttle stop screw will only affect idle speed if the butterfly is so open that engine speed cannot be controlled even with the IAC closed, or if the butterfly is closed such that opening the IAC as far as possible will not increase idle.
Here is how to properly set the stop screw, and a bit more about how the PCM uses the IAC to control idle.
Here is how to test the IAC...
cliffyk is offline
Quick Reply: 04 GT bouncing idle. I've tried all I know to do, and now I'm reaching out.
