octane quetion
Is this because the timing needs to be advanced to take advantage of the higher octane or is it because the fuel injection system will limit the amount of fuel allowed anyhow, or am i completely in left field all by myself?
It's the timing. Advancing the timing allows the engine a few more moments to burn all the fuel in the cylinder but if the fuel achieves combustion too early you get spark knock. This is why you use a higher octane fuel which is basically harder to burn in performance applications.
Believe it or not because 93 octane is harder to burn than 87 you can actually do yourself a disservice by using it if your car isn't tuned for it.
The stock 2V tune, devised to allow the engine to run on 87 octane fuel, and not damage itself in the process, sucks--big time. You can read more about that and recommended mods here..
Short answer though, generally ignition timing can be/is advanced when running higher octane fuels.
It is a common misconception that higher octane gasolInes are "harder to burn", they are not. Other than that one would be throwing money away using premium fuel in an engine that does not need it there is no downside--as has been stated above there is no upside either.
Their advantage lies solely in increased resistance to detonation--more about octane here...
