Really annoying chriping/squealing noise
So there's this noise in my car that I've been trying to figure out what the hell it is for what seems to be the longest time.
It sound like a really angry bird is under my hood/car.
It only makes this noise when the car has been sitting out for enough time to cool down a bit. And it only makes it when the car is actually moving, if I rev it up while parked it doesnt do it. The noise gets higher in pitch as the car picks up speed/rpms rise up, until the noise disappears or I stop.
I tried to get the noise as best as I could in this clip:
https://soundcloud.com/2dvh/noise
I'm pretty sure it's something from the drive train and not a pulley at this point, as I've replaced 2 pulleys with bad bearing and it still makes the noise.
The noise also doesn't come back after it goes away, the only way it comes back is if I let the car cool down for a while.
I was going to guess maybe the u-joint of the driveshaft but I'm not sure about it.
All 4 wheels? What about the rotors. Highly doubtful that it's a U joint. What about the clutch, how old is it?
Ok, thats definitely not the brakes. I've heard something similar when a brake shield is rubbing against the rotor. You need to jack it up and rotate each wheel separately and see if it's something there.
I would check if the backing plate is hitting the rotors, then check the pads, meaning take off the pads and look at the pad material to see if any rocks are in there. Then check the rotors for obvious grooving or weird marks on them. Also while you got the car in the air check the front hub bearings for looseness. One last thing is when your driving turn right and left like your weaving in and out of traffic, you'll be loading and unloading one side at a time to see if the noise is coming from the left or right side. I can only listen to the first audio but to me it sounds like the brakes.
