'96 GT has broken 2 TOB sleeves in 5000 miles
Old 01-30-2014, 11:16 PM
brbean
brbean's Avatar
Default '96 GT has broken 2 TOB sleeves in 5000 miles
I have a '96 with about 150k mi on the motor (completely stock, with new rear main seal and pilot bearing), and the trans was rebuilt around 5000 mi ago. The first time it broke, the shop I took it to just welded it back together and put the transmission back in without checking what I wanted them to do... So that may very well be why it broke the second time, but I'm doubtful because I don't think the sleeve is really under that much stress.
I'm not hard on the transmission at all (I dumped the clutch once, and power shifted into 2nd twice). I rag on it when its in gear occasionally, but I don't shift hard. I don't ride the clutch, and don't stand on it at red lights.
When it goes, it makes the distinct "TOB noise" for about 100 miles, and then starts making an awful clunking racket (presumably when it breaks), with an extreme vibration in the pedal. It also takes the friction plate out, and brakes most of the fingers on the pressure plate.
Is it possible that something is wrong inside the transmission? It shifts fine, and doesn't make much noise at all. I trust the shop that rebuilt it, as well. I'm kind of at a loss, and hesitant to have the transmission torn apart for a new sleeve if it's just going to break again. Any ideas as to what could be the cause?
brbean is offline
Old 02-01-2014, 11:58 AM
TXMach
TXMach's Avatar
What did they originally weld back together? It's possible that shafts are misaligned...
TXMach is offline
Old 02-02-2014, 01:12 AM
brbean
brbean's Avatar
They welded the sleeve back together. I'm not really sure where exactly it broke, but they told me later that they didn't want to get into taking apart the transmission to actually replace it. Is 4-5 hours right to just remove the bell housing and press in a new sleeve? At that point, would it be worth it to just have a shop tear it all down again? I can pull the trans myself, but I have no intentions of opening it up in my garage...
brbean is offline
Old 02-02-2014, 06:19 PM
BraMas
BraMas's Avatar
something sounds funny here the TOB is a bearing and there is really nothing to "weld" back together. And there is no way to remove the TOB without removing the trans. I think your shop is feeding you a load of crap
BraMas is offline
Old 02-02-2014, 11:38 PM
brbean
brbean's Avatar
Sorry, I'm doing a bad job explaining this. Not the TOB itself, but they welded the sleeve around the trans input shaft, where the TOB rides. The transmission has been out of the car twice now.
brbean is offline
Old 02-04-2014, 03:46 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
its called the bearing retainer iirc, and sounds like you might have a clutch fork issue... or the pivot ball is damaged.
WhiteFoxGT is offline
Old 02-04-2014, 04:38 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
What is TOB?
fastbackford351 is offline
Old 02-04-2014, 04:44 PM
TXMach
TXMach's Avatar
TOB = Throwout Bearing
TXMach is offline
Old 02-05-2014, 06:28 AM
fastbackford351
Foghorn Leghorn
Thanks.
I realized what it was last night just before I drifted off to sleep.
2007CalSpec
12-13-2020 11:42 AM
FivePointToTheOh
10-02-2015 04:09 PM
bconboy
09-24-2015 01:55 PM
heslekrants
09-23-2015 04:02 PM
bconboy
09-21-2015 12:52 PM
Quick Reply: '96 GT has broken 2 TOB sleeves in 5000 miles
