Battery issue?
If you're not starting it for weeks at a time it'll probably go low charge. Batteries typically last 2-4 years. If you want a battery with good reserve cold cranking amps then a autozone optima or sears diehard platinum are the way to go. If you're going to leave the car for weeks at a time with out starting it I suggest a battery tender to keep the battery from low charge. As for your battery, yeah it sounds like it needs to be charged or it's dead.
I did not know earlier but it has the small window with a red ball floating which means it is not good. Green is good. I usually do not see this type of battery. I start it on the weekends, but did not last week and this. I will just get a new battery since I believe it is original and do not want to get stranded somewhere. I appreciate all of your quick responses. Ed.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
