ac compressor swap - MustangForums.com
Old 03-20-2014, 05:06 PM   #1
soco957
soco957's Avatar
Default ac compressor swap
where do you put the compressor oil in a AC compressor on a 97 Mustang GT
soco957 is offline   Reply With Quote
Old 03-21-2014, 11:47 AM   #2
mmmdaddy57
They have cans of oil you can install using a set of gauges, or you can add it to the compressor through one of the manifold ports on the compressor. You need to know how much oil is in the system already. When you install a new compressor they tell you to drain the oil out of the compressor and measure how much came out, then adjust the level accordingly. You would have to check a manual for "that" amount.
mmmdaddy57 is offline   Reply With Quote
Old 03-21-2014, 11:48 AM   #3
Derf00
What makes you think you need compressor oil? If you need that, then you need to fix a leak first....
Derf00 is offline   Reply With Quote
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
Monte Carlo bar w/ AC fastbackford351 Classic Mustangs (Tech) 3 10-01-2015 01:24 PM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 06:54 PM
