dies when cold
Old 01-10-2011, 09:14 PM
dlensing
dlensing's Avatar
Default dies when cold
My 97 GT with 155000 miles starts ok in the morning. Whne I stop at the mailbox on the way to work it makes a howling noise and usually dies, Stats right back up and runs fine. Any ideas on wht could be wrong. No code.
dlensing is offline
Old 01-11-2011, 05:22 AM
uberstang1
Chupacabra
uberstang1's Avatar
Whens the last time you changed the plugs?
uberstang1 is offline
Old 01-11-2011, 10:09 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
This sounds (no pun intended) as though the idle air control valve has failed and is chattering rather than doing what it is supposed to--more about this here.
What you describe is exactly how mine went out, at first just honking but later stalling out when cold...
cliffyk is offline
Old 01-11-2011, 08:25 PM
65mechanic
65mechanic's Avatar
does this howling sound increase in noise when you rev the motor? I have a similar noise when the car is cold.
65mechanic is offline
Old 01-11-2011, 08:50 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
In my experience the IAC related "howling", "honking", "French horn" noise has been unrelated to engine speed, and discontinuous--often silenced by "blipping" the throttle.
I would suggest that you may have another issue, perhaps related to some engine driven auxiliary device. Failed/failing generator, power steering, water pump, or idle pulley bearings can create engine speed related whines/howls/etc...
cliffyk is offline
Old 03-23-2014, 08:46 PM
dlensing
dlensing's Avatar
Default iac valve
It was the IAC valve
dlensing is offline
4cylinderplus2
10-09-2020 07:45 PM
Dokilar
15
10-16-2015 08:13 PM
Explosive
10-02-2015 07:45 AM
RCS02v6
09-29-2015 01:46 PM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: dies when cold
