Passenger front Caliper sticking after pad change
Old 03-29-2014, 11:14 AM
03'mustangGT
03'mustangGT's Avatar
Default Passenger front Caliper sticking after pad change
Whats up guys. Tried searching the forums for similar experiences and had no luck so here I am. Just change pads on a 2003 GT for the first time and after putting them on the front passenger side is giving me problems. First of the back side pad didn't slide in very easily and then after putting the caliper back on the brakes stay stuck on a little bit. Not to the point of being locked up but the car wont roll freely and if I drive it too far they start to smoke a bit. Only issue I had before doing the brakes was the e-brake was sticking on. Cant figure it out, hoping I don't need a new caliper.
03'mustangGT is offline
Old 03-29-2014, 08:36 PM
Chubstang
Chubstang's Avatar
Did you clean and grease the slides? My first guess is the new pads aren't moving freely enough.
Chubstang is offline
Old 03-30-2014, 08:10 AM
96t-bird
96t-bird's Avatar
+1 on, that , also check brake hose. hose maybe collapsing.
96t-bird is offline
Old 04-02-2014, 12:09 PM
henryford
henryford's Avatar
My three fords have had your problem and no one seems to get it! The plastic pistons seem to grow over time and get larger at the pad end. When you push the pistons back in they bind and stick. I've had to replace pistons with steel if posible. Its either that or replace calipers. Replaceing pistons is a challenge. Mianly getting the dust boot in place while inserting the pistons.
henryford is offline
Old 04-02-2014, 12:25 PM
henryford
henryford's Avatar
I'm presently replacing the pistons in 2004 GT. The car has 18K miles, this piston problem seems to be time dependant. 9-10 years for me and then the brake stick and or start getting hot. Pad replacement moves the piston back into the caliper and on an older vehicle causes the same brake issue,. Also to remove a stuck piston be careful. A 2 x 4 between the caliper and piston helps when you use air to pop it out. (more like explode). Think safety when removing the pistons! Best of luck in your repiars. PS I'm looking for the specs for the brake line tightening torque. no luck so far.
drfister
05-03-2018 10:38 PM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Saylor12
08-23-2015 06:31 AM
inyadreems
08-21-2015 09:10 AM
Quick Reply: Passenger front Caliper sticking after pad change
