Weird Mustang Overheating
Old 04-03-2014, 11:42 AM
Tomtom9401
Tomtom9401's Avatar
Default Weird Mustang Overheating
Hey guys I am having a little trouble out of the Stang randomly the other day. The car has only 80k miles on it. Basically I was just sitting in a parking lot with the AC on and all of sudden my car jumped into the red on the heat gauge and coolant exploded out of the reservoir via the pressure cap. The car has done it a few times now, but it seems it drives fine up until I turn the AC on. The gauge stays in the middle and can tell when the thermostat opens up via the gauge also. I have replaced the thermostat, belt, and temp sensor. A few other weird things I was noticing. Apparently my radiator fan keeps blowing the fuse, so it doesn't work, and also when my cars AC kicks on the AC compressor bogs my engine down way below idle; almost cutting the car off. At first I thought it could be a head gasket with my luck, but considering the mileage im hoping this isnt the case. Is it possible that the AC compressor could put enough strain on the engine to cause it to overheat; in conjunction with the fan not working of course. Any help/advice will be greatly appreciated. Thanks!
Additional info: 2004 Mustang GT, the car doesn't appear to "gradually" heat up, rather jumps pretty much from middle to high in less than 5 minutes
Tomtom9401 is offline
Old 04-03-2014, 01:16 PM
dawson1112
dawson1112's Avatar
Any time the AC compressor kicks on the fan will kick on high as well. So if your blowing fuses I suspect it is something in the fan schematics causing your issue.
You could have a bad fan motor, or a failing relay , possibly even a bad ground .
dawson1112 is offline
Old 04-03-2014, 01:43 PM
Tomtom9401
Tomtom9401's Avatar
Would this cause the car to overheat though?
Old 04-03-2014, 01:57 PM
dawson1112
dawson1112's Avatar
Yea if your fan is not running at the proper rpm . or putting excess drag on the system.
NorthAmericanTuning
03-18-2016 11:21 AM
antipeterleague
08-18-2015 01:50 PM
daytooday
08-11-2015 09:22 AM
yurizx6r
08-11-2015 07:50 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Weird Mustang Overheating
