Topping off Manual Transmission Fluid
Old 04-05-2014, 07:00 PM
TheMouseRan
TheMouseRan's Avatar
Default Topping off Manual Transmission Fluid
I've found several posts saying that there is a plug near the top of the transmission underneath my 1997 manual Ford Mustang.
I have also found articles saying that overfilling a transmissions fluid is very bad.
I have a slow leak in my transmission, and normally have the trans topped off when I get my oil changed. They had no trans fluid to do this with, so I bought Mercon V Automatic Transmission and Power Steering Fluid & plan to do it myself.
Full disclosure, I have no idea what I'm doing. I found a video of what the trans looks like, and think I can find it. My main worry is that I will overfill my transmission... and what if I don't find this magic trans fluid fill nipple after all?
Halp?
TheMouseRan is offline
Old 04-06-2014, 04:50 PM
ESABATM
ESABATM's Avatar
Halp?
Find the drain plug on the bottom. Move up the right side from there is the fill plug.
ESABATM is offline
Old 04-07-2014, 04:28 PM
tracyballard
tracyballard's Avatar
But don't fill it up all the way to the top fill plug, it should be about half an inch or so below the level of the top plug, just full enough that you can touch the fluid if you stick your finger in there.
tracyballard is offline
Old 04-07-2014, 08:23 PM
8111870a
8111870a's Avatar
^^^^Vehicle has to be level, either on stands or on lift.
8111870a is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Pyrate Dave
09-10-2015 07:30 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: Topping off Manual Transmission Fluid
