Squeal possibly from the AC compressor?
Old 04-13-2014, 12:19 PM
Jayhawks
Jayhawks's Avatar
Default Squeal possibly from the AC compressor?
I'm trying to diagnose the squeal noise I'm hearing. Squeals at all RPM, even at idle. When the AC is turned on the sound gets a lot louder so I think it is the AC compressor. However the AC still works well. How can I tell if it's the compressor clutch or the whole ac compressor?
Or is it possible that it has nothing to do with the AC compressor and it's the belt or tensioner or pullies? I did a quick inspection of the belt and it looked fine, but it definitely could use a closer look.
It's a 2004 5speed
Jayhawks is offline
Old 04-13-2014, 01:33 PM
school boy
school boy's Avatar
Check and see if its not an idler or tensioner first, this would be my first guess. When the ac is activated, it puts more strain on the idlers and could cause them to make more noise when the bearings are getting worn in them.
school boy is offline
Old 04-13-2014, 03:08 PM
Jayhawks
Jayhawks's Avatar
Okay, what's the best method for testing them? Thanks
Jayhawks is offline
Old 04-13-2014, 07:30 PM
school boy
school boy's Avatar
lol, that's a good question! As the car's running check under the hood and listen. Next check if any of the idlers have excess play. then go from there.
Old 04-14-2014, 07:10 AM
robb15033
robb15033's Avatar
One bearing should be louder than others, causing squeal.
robb15033 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
fastbackford351
10-01-2015 12:24 PM
winner99
09-30-2015 07:04 PM
Quick Reply: Squeal possibly from the AC compressor?
