High mileage differential oil change... - Page 2 - MustangForums.com
Old 05-17-2014, 02:34 PM   #11
cliffyk
TECH SAVANT
cliffyk's Avatar
Here is the '96 through '04 Redbook information, note that Traction-lock was never offered as an option.
Many confuse the PCM/ABS controlled Traction Control and Traction-lock. T/C was standard in most MYs, but optional in a couple...
cliffyk is offline   Reply With Quote
Old 05-17-2014, 02:37 PM   #12
VTX1800N1
Yep, you are right. I know the difference between a LS rear (traction lok) and traction control. I could swear I saw a magazine review of these model years that said the LS was an option, but they could have gotten it wrong too.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline   Reply With Quote
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
cost to rebuild heads Drastang 4.6L (1996-2004 Modular) Mustang 2 09-30-2015 04:48 AM
Hi - Yes, I'm a gal and need help CS2007 General Tech 7 09-29-2015 08:38 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
