Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Sign in using an external account
Register Forgot Password?
Search
Sponsored by Cruizin Concepts
Welcome to Mustang Forums!
Welcome to Mustang Forums.
2004 Mustang GT High Idle **HELP**
Old 05-23-2014, 11:18 AM   #1
Roob
Roob's Avatar
Vehicle: 2004 Mustang GT
Default 2004 Mustang GT High Idle **HELP**
I have 2004 Mustang GT 152K miles - all stock
I have an High Idle Problem and Stalls
Idle is 2000 rpm.....
Once I tap the EGR Valve it stalls .. If I tap the EGR valve give it a little gas it goes back to normal idle 600 rpm
I have replaced the TPS Sensor, IAC Valve, EGR Valve, mass Air Flow Sensor
nothing .... still idle high
I checked for vacuum leaks cant not find any.
can anyone give suggestions?
Thanks
Roob is offline   Reply With Quote
Old 05-23-2014, 11:30 AM   #2
DeathRattle
Vehicle: 2003 Ford Mustang GT
Is the throttle blade sticking?
__________________
Esmeralda - 03 Stang GT: Sniper tune, PP intake/plenum/75mm TB, CAI, Full O/R Exhaust, UDP's, Cobra tank, dual 255 lph pumps, 4.10's, upgraded trans w Transpak, 2400 stall converter, grille delete...
Nadia - 2010 Camaro LS3 2SS/RS: SLP Blackwing, K&N Air Filter, SLP Under Drive Pulley, VMax TB, OBX 1-7/8 LTs with HF Cats, OBX 3" Cat-Back, Custom Predator Tune!!
DeathRattle is offline   Reply With Quote
Old 05-23-2014, 12:13 PM   #3
Roob
Roob's Avatar
No .. Cable, cruise control cable, all is fine
Old 05-23-2014, 12:46 PM   #4
art02gt
art02gt's Avatar
Vehicle: 2002 Mustang GT
how did you check for vacuum leaks?
Any codes?
__________________
2002 GT: 4.10s, AM CAI, UPR o/r X-Pipe, MGW STS, Flowmaster 40's, more to come
art02gt is offline   Reply With Quote
Old 05-23-2014, 01:00 PM   #5
Roob
Roob's Avatar
No check light is on
I checked for vacuum leaks with carb cleaner
checked everywhere ...
any other way I can check?
Old 05-23-2014, 01:04 PM   #6
art02gt
art02gt's Avatar
Having the check engine light off doesn't necessarily mean you don't have any codes. You can have what are called 'pending codes' and can be a huge clue to what's causing your problem. If you can get a hold of a scan tool, it would also be a big help to see where your fuel trims are at.
__________________
Old 05-23-2014, 01:09 PM   #7
Roob
Roob's Avatar
I can go to autozone, they do it for free
how long does my battery need to be hooked up to get codes?
Old 05-23-2014, 01:19 PM   #8
art02gt
art02gt's Avatar
there really is no telling. Each monitor has a specific criteria it needs to meet before completing. just drive it normally for a week or so. The people at autozone might not give you the pending codes though, around here they've become real jack asses that wont even hook up the scan tool if the CEl is not on and they won't want to listen to anything you have to say about it.
__________________
Old 05-23-2014, 01:28 PM   #9
Roob
Roob's Avatar
ill do that .. thanks
Old 05-23-2014, 02:53 PM   #10
Derf00
Vehicle: '08 S197 GT
Could be the DPFE sensor is sticking... When it goes bad it usually, but not always, throws a code.
__________________
08 S197 GT Auto: FRPP Strut Tower Brace, FRPP Bullitt CAI, Bama 91-P Tune, VBX remaned valve body with Superior Transmission Shift Kit.
Pending upgrades: Shaftmasters Aluminum 3.5" DS, FRPP 3.73 gears, Axle back exahust (?)
Quote:
Originally Posted by LostBoyz View Post
if you are getting 29mpg in your 5.0, you aren't driving it correctly
Derf00 is offline   Reply With Quote
Old 05-23-2014, 03:12 PM   #11
Roob
Roob's Avatar
Ive replaced the DPFE sensor too
im stumped
Old 05-23-2014, 03:22 PM   #12
Roob
Roob's Avatar
I have replaced the DPFE sensor too
Old 05-24-2014, 02:37 AM   #13
DeathRattle
When you replaced the TPS did you check the voltage? If the voltage is off then you will have idle problems. One thing you could try is adjusting the butterfly stop on the TB...as a last resort if you can't find the issue.
__________________
Old 05-24-2014, 09:14 AM   #14
Roob
Roob's Avatar
I have check the TB all seems ok ...
here's my question to you...
when I tap the EGR and give it a little gas the idle goes to normal...
so I think the EGR has something to do with it...
How much suction should the little hose that connects on top of the EGR have?
should it be strong?
Old 05-24-2014, 12:21 PM   #15
art02gt
art02gt's Avatar
That has engine vacuum and if i remember correctly there should be no vacuum at idle (egr closed). Check the vacuum solenoid that hose goes to. How clean were the egr passages on the motor side when you replaced the erg valve?
__________________
Old 05-24-2014, 04:49 PM   #16
Roob
Roob's Avatar
I replaced the Vacuum Solenoid too
Just seems like the issue has something to do with the EGR Valve, because when I tap the EGR Valve and give it a little gas the idle goes back to normal 600 prm
Old 05-24-2014, 05:08 PM   #17
CalBoy101
Vehicle: 2002 Ford Mustang GT
It sounds like you have a sticky EGR valve. This happens as they get carbon built up in them.
You can try cleaning it but might just need to replace it.
CalBoy101 is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
