Passive Theft problem
Old 05-26-2014, 02:55 PM
mjmeyerpa
mjmeyerpa's Avatar
Default Passive Theft problem
I recently purchased a 94 Mustang street custom with a built 351W motor (retirement hobby). It has run great all spring and today after a drive, I went to start it to put in garage and no ignition? All lights, turn signals, radio etc work. It has an external fuel pump with dash switch and that works as well, until I turn the ignition key and it is then disabled along with no spark or starter. I disconnected the battery for 30 min., and when I hooked it back up, the alarm went off with lights and horns. I have checked all the fuses and everything looks fine.
Should I suspect that its a bad anti-theft module in the trunk?
Any help/suggestions would be much appreciated.
mjmeyerpa is offline
Old 05-26-2014, 04:21 PM
sv650lex
sv650lex's Avatar
Check battery voltage first. It should be over 13 volts. I had a Yukon that acted like that and all it needed was a battery.
sv650lex is offline
Old 05-26-2014, 04:43 PM
mjmeyerpa
mjmeyerpa's Avatar
It shows 12.7V.....I'll put it on charger overnight, but as I said, all other electronics work as they should. It's seems to be just the starter circuit that's disabled. Thanks
Old 05-29-2014, 02:40 PM
mjmeyerpa
mjmeyerpa's Avatar
Problem solved.....thanks
JoshyGT
09-19-2017 08:52 PM
piotrek53
10-13-2015 06:54 PM
stangin1996gt
09-21-2015 11:01 AM
Beerman309
09-19-2015 01:16 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Passive Theft problem
