98 cobra CCRM
Old 06-15-2014, 05:12 PM
andrew22888
andrew22888's Avatar
Default 98 cobra CCRM
Ok I bought a 98 cobra it had a couple issues. First off the fan has a toggle switch hooked up to it and still has the stock wires hooked up. It works on low but not on high unless I turn the toggle on. It was also throwing a lean code tell I reset the computer. Now it's just throwing a evap sensor code. That is the only code it's throwing which I ordered the part. But the issue is it's still cuts out sometimes. And today it actually stalled right on it's face like I was running out of gas and at one point was just stuck at 3900 rpm now matter how much gas I gave it. And also the IRMC are not opening but I can open them freely by hand. But I'm not getting a code for that. So what I am wondering with all these issues does it sound like it could be the CCRM causing these issues. Or do these all not relate?
andrew22888 is offline
Old 06-17-2014, 11:26 AM
BraMas
BraMas's Avatar
The IMRC's do not open until 3250rpms so if your haveing trouble with car falling on face after that I would assume they are not opening properly. zip tie them open and see if that helps if it does delete or clean them
BraMas is offline
Old 06-18-2014, 06:18 PM
andrew22888
Well I have all the codes away now but a p1151 what could that be its a lean code and sometimes it acts like its running out of gas and stall but u stop to a idle and it revs fine its like a issue under load.
Old 06-19-2014, 02:24 PM
uberstang1
Chupacabra
uberstang1's Avatar
The imrc not opening at speed would def cause it to feel flat, there nothing but issues on these cars, delete them and never look back.
uberstang1 is offline
Old 06-20-2014, 05:01 PM
andrew22888
It was a ground issue with the cutting out. Now i'm just working on the lean bank 2 code.
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Dan04COBRA
09-30-2015 11:46 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: 98 cobra CCRM
