Help me fix grandma's mustang please
It sure sounds like an O2 sensor. I think you need a more specialized scanner to get the specifics on which one it is though. I would see if you can find someone near you who has an SCT tuner (or similar) that you could borrow...those will log data to a PC, and give you sensor readings that should help troubleshoot this.
So many things it could be...found this pretty comprehensive list on another forum, some you've obviously already ruled out though:
Fuel system
- Excessive fuel pressure.
- Leaking fuel injector(s).
- Leaking fuel pressure regulator.
- Low fuel pressure or running out of fuel.
- Contaminated fuel injector(s).
- Vapor management valve (VMV) leaking.
Induction system
- Air leaks after the MAF.
- Vacuum leaks (vacuum lines and gaskets).
- Restricted air inlet.
- PCV system.
- Fuel purge system.
- Improperly seated engine oil dipstick.
EGR System
- leaking gasket.
- Stuck open EGR valve.
- Leaking diaphragm.
Base engine
- Oil overfill.
- Cam timing.
- Cylinder compression.
- Exhaust leaks before or near the HO2S(s).
Fuel system
Induction system
- PCV system.
EGR System
- leaking gasket.
Base engine
- Oil overfill.
- Cam timing.
MtnMustang
08-16-2015 08:07 PM
KEM Motorworks
08-14-2015 10:13 PM
