I just replaced the Serpentine belt
Old 08-17-2014, 09:50 PM
ckrei06
ckrei06's Avatar
Default I just replaced the Serpentine belt
Now I am seeing sparks coming from the tensioner.
ckrei06 is offline
Old 08-18-2014, 01:43 AM
VTX1800N1
VTX1800N1's Avatar
Did you take the tensioner off the timing cover for some reason?
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 08-18-2014, 09:12 AM
ckrei06
ckrei06's Avatar
Could you please elaborate, I'm kinda auto illiterate.
ckrei06 is offline
Old 08-18-2014, 09:22 AM
VTX1800N1
VTX1800N1's Avatar
The tensioner is what you have to rotate with a socket driver or breaker bar to relieve tension on the belt so that you can remove or install it. Did you also unbolt it from the engine (timing cover) for any reason?
Old 08-18-2014, 09:31 AM
ckrei06
ckrei06's Avatar
No I haven't
ckrei06 is offline
Old 08-18-2014, 03:01 PM
kast1376
kast1376's Avatar
Where on the tensioner are the sparks coming from? Can you take a pic and then circle the area?
kast1376 is offline
Old 08-18-2014, 03:40 PM
Z28KLR
Z28KLR's Avatar
^ What he said.
Be sure the tensioner is attached to the timing cover firmly (it's just one bolt, more or less in the center of it. I forget the torque spec for that bolt, but it's not much - maybe like 20lb/ft or something). If it is, and it's grinding up against the timing cover then the bearing/bushing in the tensioner is shot and the whole thing needs replaced. Not a big deal - it's about $35 at Autozone and 10 minutes of your time.
Don't let it rub against the timing cover very long; the timing cover is aluminum and not very thick, and the pulley on the tensioner is steel. The pulley will win that fight, and when it does it will be a much bigger job. When my tensioner went, it took out about 1/16" of material from the timing cover in less than a few minutes.
Z28KLR is offline
Old 08-20-2014, 03:01 PM
WJL
WJL's Avatar
the last time i checked the timing cover is aluminum hard to get sparks from aluminum? check the pulley bushing may be frozen and rubbing against the mounting bolt JMAO
WJL is offline
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Quick Reply: I just replaced the Serpentine belt
