Engine won't idle when warm
My 98 GT will not idle at the proper RPM when the engine gets up to operating temp. Normally it idles around 800 RPM when warm, now it's under 500 and I have to keep my foot on the accelerator to keep the engine from stalling. What ever is causing the problem does not trip the check engine light. Any ideas you may have as to whats causing the problem are greatly appreciated. Thanks.
Could be bad IAC valve, bad IAT sensor (intake air temp), ECT (engine coolant sensor), TPS (thottle position sensor), MAF or a sticky EGR valve, when they stick open they cause idle problems.
Do you have a way to datalog and see what values you are getting from the IAT, ECT, MAF and TPS sensors?
You should also check the fuel pressure.
ShaneB26154
35
03-04-2021 04:05 AM
