New Mid pipe now I get 40MPG?!
Old 08-23-2014, 05:13 PM
MontieShaw
MontieShaw's Avatar
Default New Mid pipe now I get 40MPG?!
Hey everyone, im curious if you can help me out. I just installed pypes high flow cats and pypes off road H pipe on my car and now my average mpg is around 40 when driving. That cant be right. I already had pypes violators on my car and it never did this before. There are only two seals that leak and its at the front (towards the engine) of both cats. Nothing else leaks. How are MPGs calculated?Could it be an O2 sensor went bad, or could the 2 leaks i have right before the cats be causing this?
MontieShaw is offline
Old 08-23-2014, 06:17 PM
dawson1112
dawson1112's Avatar
Not 100% certain, but I think they use a wideband 02 to calculate fuel economy.
If the leak in the exhaust is before the upstream 02 sensors there is a good chance that is causing it. Im surprised your not throwing a lean code.
dawson1112 is offline
Old 08-23-2014, 07:29 PM
outceltj
outceltj's Avatar
So u don't know how to hand calculate your mpg?????
outceltj is offline
Old 08-23-2014, 07:37 PM
MontieShaw
MontieShaw's Avatar
It actually threw a code after driving about 5 miles after swapping my downstream O2 sensors from before the cats (I drove about 100 miles with no code while was waiting until my O2 sensor extentions to come in) to behind the cats. I unplugged the battery and cleared the code because I thought maybe swapping the holes caused it. Ive driven 30 miles since clearing it and it hasnt come back yet.
Old 08-23-2014, 07:38 PM
MontieShaw
MontieShaw's Avatar
Are you talking about going to a gas station, filling up, drive and then come back and see how much gas you need to fill it up again?
Old 08-23-2014, 08:21 PM
LilRoush
LilRoush's Avatar
Yes, you need to measure the amount of gas you actually burn and divide it by the miles you drove to burn it. That is the ONLY way to measure MPG. Also, make sure your miles are reading correctly. Over/undersize tires and aftermarket (uncorrected) gears will mess that up.
LilRoush is offline
Old 08-24-2014, 07:09 AM
outceltj
outceltj's Avatar
Yes computers will vary by a lot or sometimes minimal
outceltj is offline
ctgreddy
10-14-2015 09:05 PM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
BrantleyS550
09-14-2015 04:18 PM
Webster454
09-07-2015 04:59 AM
Quick Reply: New Mid pipe now I get 40MPG?!
