Replaced cracked intake manifold, now knocking at wot
Old 08-27-2014, 10:41 PM
kast1376
kast1376's Avatar
Default Replaced cracked intake manifold, now knocking at wot
Need some educated guesses here! Recently replaced the intake manifold, and now when I go WOT, I get knocking. No knocking otherwise in any gear at any speed or at idle.
Any ideas?
kast1376 is offline
Old 08-31-2014, 02:46 PM
JC316
JC316's Avatar
Why did you have to change the intake? Best guess is that you have a vacuum leak that's leaning you out and causing detonation.
JC316 is offline
Old 08-31-2014, 04:56 PM
bluebeastsrt
bluebeastsrt's Avatar
Vacuum leak! End thread.
bluebeastsrt is offline
Old 08-31-2014, 08:34 PM
kast1376
kast1376's Avatar
The intake cracked where the plastic joins with the aluminum cross over. Will start looking for a vac. Leak somewhere. Thanks guys!
kast1376 is offline
Old 08-31-2014, 08:37 PM
99GTvert
is my username.
99GTvert's Avatar
That sucks. Did you use new gaskets for the intake? All your hoses plugged in? Is the new intake itself alright?
99GTvert is offline
Old 08-31-2014, 08:49 PM
uberstang1
Chupacabra
uberstang1's Avatar
check the new intake for cracks as well, if u have acces to a vacum smoker thats your easiest way to find the leak.
uberstang1 is offline
Old 09-01-2014, 02:08 AM
kast1376
kast1376's Avatar
All new gaskets, all hoses plugged in.
Uber, what is a vac. Smoker?
Edit: I wish I had access to a smoker! I really hope the intake isn't f%#ing cracked. If it is hopefully AM will replace it.
It's gonna be hard to track down. There is no issue at all until WOT, so I don't think the standard carb cleaner check will work.
kast1376 is offline
djbigskrilla
09-20-2022 01:04 AM
Spiral534
10-06-2015 04:31 PM
Calizic
08-28-2015 01:46 PM
soulcaliber39
08-26-2015 03:26 PM
Quick Reply: Replaced cracked intake manifold, now knocking at wot
