Need Help Passing Emissions....
Hello everyone,
Is anyone familiar with how long it takes that computer to recycle in my 02 GT? Unfortunately, it had been sitting since last Thanksgiving up until a little over a week ago. I've put over 400 miles on it (mostly highway) over the ast seven days, and I have put two fresh tanks of 93 in it; one of which had this "Guarrantreed to Pass Emissions Test" formula in it. Low and behold I have failed my emissions test TWICE NOW! I have passed my emissions test three times with the same setup previously. I have not made any changes at all. The only difference is that this car has been sitting for about 8mths unfortunately....
While it was sitting I kept it on a battery tender and I had a full tank of fuel in the car fuel stabilizer as well. The car seems to be running fine to me. I am not seeing any codes and have no issues driving the car. I just can't seem to pass this stupid test. A friend of mine said I should unhook my battery, re-hook it, and then continue driving it. Any help and advice will be appreciated. I can email anyone pics of the emissions slip showing the test information. I thought I could attach it here, but looks like I need a URL. Thanks in advance.
Hey Derf,
I can send you pics of my emissions sheet if you want. Just pm me your email address. It's saying the monitor is not reading the cats or O2's. Thing is, they have been off the car for 11yrs and I have passed with the same setup three times already. A buddy of mine has the monitor portion showing "READY" where as mine reads what I stated above and he is also running no cats same as me. They are doing and OBDII computer test.
If the car still mostly has 8 month old fuel in it I'd dump that fuel or drive it until the tank is empty and put fresh regular in it for the test. Even with a stabilizer the alcohol content in the fuel likely absorbed some water and I think there are other fuel components that break down over time also.
When you get fresh fuel in it get on the freeway and do some spirited driving to try to get any built up carbon deposits out of the engine and hopefully to get some cleaning action on the injectors from the higher flow at WOT.
Make sure the car is warmed up well (freeway is good) prior to the test. If they let it sit to long, start it up to keep it warmed up before the test.
Hey Derf,
If you have your stock mid pipe throw it back on just for emissions.
That's your problem. If you don't have cats you're not going to pass the visual inspection. Plus if you took off that cats and used a tuner to shut off the sensors it will show up as "not ready" on your emissions sheet. That too will fail you.
Those monitors they use to read the emission stuff in the car are always getting new and improved software updated to them, its possible the newer software is programed to look at other parameters besides a ready code.
Yes, I am taking it to the same place and yes I am using MIL's. I have a theory though, so and I plan to see how it goes on Wed or Thursday. Stay tuned....
I have a 2001 Mustang GT with a Magna flow exhaust system.The "service engine soon" light came on because of the after market catalytic converters.I had a garage shut the light off and I drove the car about 90 miles and it passed inspection.
