2001 mustang gt coupe gear change
Old 09-07-2014, 11:40 AM
tadpole1969
tadpole1969's Avatar
ok i sure thank you for the good info dawson! gonna get the 3.73 installed tommorow and tuner is ordered so i will let you know how it goes thx again
tadpole1969 is offline
Old 09-08-2014, 10:50 AM
tadpole1969
well the old ponys in the shop getting gear installed! cant wait to get it back and see how she feels!
Old 09-08-2014, 11:22 AM
dawson1112
dawson1112's Avatar
Congrats you will thank your self with in the first 60ft.
dawson1112 is offline
Old 09-09-2014, 09:58 AM
01S2Roush
01S2Roush's Avatar
Originally Posted by dawson1112
The gears should have the ratio stamped into the ring gear someplace that you can read with the cover off. If not you can lift the rear of the vehical, make a mark on the inside of the rear wheel, then rotate it 1 full turn counting the number of revolutions the drive shaft makes. So if the gears are 3.73 the drive shaft would rotate just a tiny bit under 3 3/4 turns.
3.27 gears the drive shaft would rotate just a tiny bit over 3 1/4 turns per 1 revolution of the tire.
That's great info, I'll try that thanks! My gear oil is changed and the tag still said 3.27, so they're stock unless the tag wasn't changed. Not sure why the speedometer is 10 mph then, any ideas?
01S2Roush is offline
Old 09-09-2014, 02:08 PM
dawson1112
dawson1112's Avatar
They typically don't change the ID tag on the differential when they do a gear change. Heck I have never known for it to be changed. Nor have I ever installed a set of gears that came with a new ID tag.
In order to know what gears you have you must visually verify them , or count the number of drive shaft rotations per 1 rotation of the tire.
Changing tire size can also affect the speedometer reading. Going to a larger or smaller diameter than what came from the factory.
Also thinking about it , the gear ratio is often stamped into the inside end of the pinion gear.
Old 09-09-2014, 07:14 PM
tadpole1969
got the gear installed for 450.00 parts and labor love it! now just waiting on my tuner to get here thursday. so i can tune it for new gear setup
Old 09-10-2014, 04:17 AM
dawson1112
dawson1112's Avatar
Did it really wake that car up? Every car I ever put gears in made it feel like she was drinking redbull lol .
Old 09-10-2014, 05:02 AM
tadpole1969
yeah it woke it up for sure! got some get up and go outta the hole now , and once i install the performance tune on it itll really get a wake up slap lol
Old 09-10-2014, 10:34 PM
tadpole1969
got my tuner today installed the preloaded tune after i edited the user option for the axle ratio to 3.73, only thing is rpms in 1st gear, go to 3000 rpms! which is way to high for first gear before itll change outta 1st, any ideas what needs to be done dawson or anyone that has done this tuneing before , i returned it to saved stock file till i get it figured out ! really wish i had the sct advantage software to edit the tune file my self
Old 09-11-2014, 05:32 AM
dawson1112
dawson1112's Avatar
I am assuming you have an auto trans?
Who did the tune for you? Its kinda common for a canned performance tune to raise shift points in your automatic transmission. That's how performance modes are on modern cars that have a sport button on the shifter. That's the way performance tunes work. The idea is that at lower speeds it keeps your rpms in the optimal power band range. This enables you to rapidly accelerate with the maximum amount of power from a low speed take off. The down side of this is that your trans remains in first gear longer than normal when your driving it in normal traffic.
My moms Saab does the same thing when sport mode is selected. Below 30mph the trans refuses to shift out of 1st , but it makes accelerating much more exhilarating.
Obviously with a tune that is preprogrammed there will be slight variations from car to car, that is why most guys get a custom tune done at the dyno.
Quick Reply: 2001 mustang gt coupe gear change
