Cant Shift
Old 09-11-2014, 11:34 AM
Valnar300
Valnar300's Avatar
Default Cant Shift
OK, so I burned the clutch a bit yesterday because some jackass cut me off, and Then I couldn't shift into any gear, as I was rolling. I had to force it pretty hard, but no grinding or anything like that, and it went into gear and as I was driving home it felt fine again.
This morning I cant shift into any gear from parked with the engine on.
The clutch feels the same, theres no resistance/whine/grind.
I dont think it's the TO bearing, its more like the clutch operates, but the disc is stuck to the flywheel.
Any ideas?
Valnar300 is offline
Old 09-11-2014, 12:44 PM
Z28KLR
Z28KLR's Avatar
Does it move from gear to gear freely with the engine off?
Z28KLR is offline
Old 09-11-2014, 03:11 PM
Valnar300
Valnar300's Avatar
Yes it does
Old 09-11-2014, 03:31 PM
dawson1112
dawson1112's Avatar
Sounds like the clutch is not fully disengaging. Try holding the pedal to the floor with your hand , and use a large screw driver to hold the quandrant in place while you lift the pedal a few clicks.
In a moment of panic you probly activated the clutch cable tension release , It happens if you pull up hard on the pedal , or your foot slips off the clutch and pops back up.
dawson1112 is offline
Old 09-11-2014, 11:07 PM
Valnar300
Valnar300's Avatar
Aaaand I have an aftermarket Steeda quadrant. No real adjustment there.
Old 09-11-2014, 11:16 PM
Valnar300
Valnar300's Avatar
And I just got it to work again :/
I started it, then put the shifter up against 4th, where it was grinding, it wound down on grinding, and then it went into 4th, and every other gear. How utterly bizzare.
Old 09-11-2014, 11:59 PM
dawson1112
dawson1112's Avatar
lol Aaaand those are the things that are helpful to know
Check your clutch fork and make sure it didn't come off the pivot ball
Old 09-25-2014, 12:41 AM
Valnar300
Valnar300's Avatar
That and a seized pilot bearing and grumbly TO bearing. I think it was the pilot that was causing the trand to not wind down until it was forced
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Cant Shift
