tuner and octane
Old 09-20-2014, 06:11 PM
tadpole1969
tadpole1969's Avatar
Default tuner and octane
ok got a question i have the 7015 sct x4 tuner it has the preloaded tune file that my dyno tech edited for my 2001 gt, from what he told me i can use 93 octane in it with no ill effects by simply picking 93 octane from within the tune before programing it to my car ,have any of guys and gals used 93 octane in the 4.6 motor? it calls for 87 octane from factory so i do not wanna screw something up! i want to make sure its safe , the preloaded tune has options for 87 octane all the way to 93 octane in the user editable options, so its my guess that it will correct everything needed for 93 octane dureing the programming process
tadpole1969 is offline
Old 09-20-2014, 06:47 PM
yourmom6990
yourmom6990's Avatar
As long as the car is tuned for a specific octane, you will be fine. You can always run a higher octane with a lower octane tune, but NEVER visa versa. A higher octane fuel ensures that more fuel is burned within the cylinder resulting in better performance. It is not going to hurt the engine. Just be sure never to run a lower octane w a higher octane tune.
yourmom6990 is offline
Old 09-20-2014, 06:57 PM
tadpole1969
ah ok! yeah dyno tech had said that also not to run anything lower if i used 93 octane in tune options which i kinda thougth that before hand , but never hurts to get a 2nd opinion thx for the input ,also i got about a quater tank left think i should run it lower or am i good to go to fuel it up on 93
Old 09-20-2014, 09:09 PM
yourmom6990
Before I tune mine for a different octane, I usually run it down a few miles even after the light comes on. Then fill it with 93. Just to be safe, I would wait until the light comes on at least.
Old 09-20-2014, 10:36 PM
tadpole1969
k will do thx again
Old 09-21-2014, 01:34 PM
school boy
school boy's Avatar
Actually, higher octane is harder to combust resulting in a more advanced timing. If you run 87 octane on a 93 tune, you are more likely to create detonation. It is given that in most cases, more fuel is needed when a higher octane is used.
school boy is offline
Old 09-21-2014, 03:17 PM
tadpole1969
yeah i kinda figured it migth use more gas with 93 octane, but can always return to stock and use 87 again for long trips
Old 09-21-2014, 03:21 PM
school boy
school boy's Avatar
It wouldn't be that much of a noticeable difference
Old 09-21-2014, 04:03 PM
tadpole1969
performance wize there should be a small increase in hp so dyno tech said anyhow by useing 93 and nothing at all useing 87 with custom tune he put on it
Old 09-21-2014, 06:39 PM
school boy
school boy's Avatar
Either tune is going to gain hp, especially under the hp curve. Lets say as an example the tuner claims 35rwhp and we will say a bone stock GT is 225rwhp. You may only gain 5-8 rwhp at peak but 33-37rwhp at say the 4250rpm mark.
Quick Reply: tuner and octane
