Rpm problems
Rpm problems
Hi guys i have a 2000 Mustang GT and i have some rpm problems. Whenever Im driving and about to make a stop, the rpms suddendly drop to the point that it turns off. I took it to firestone and they told me it was a gas leak on a pcv hose on the throttle body, the weirdest thing is that it didn't use to do that before i had it. Before all these i had some problems with a p0171 code. Could you all tell me what to check or inspect for? Thank you
you have a 171 code, so you have a lean code. which indicates a vacuum leak. Which if severe enough will cause stalling issues. Get the leak resolved, and have the KAM reset so your fuel tables go back to normal
Omgitsa88Stang
10-05-2015 07:33 AM
musnicki
09-23-2015 07:11 AM
panic
09-10-2015 05:56 PM
zanemoseley
09-06-2015 12:58 PM
