Help me choose a harmonic damper
Old 10-17-2014, 09:21 AM
VTX1800N1
VTX1800N1's Avatar
Rebuilding my son's 2002 GT engine, I'm about to order more parts and have to choose a damper. LMR sells some for less than $200, but I haven't heard of those manufacturers before. The two big players in the damper field are ATI and Fluidampr.
Cost for either is the same at ~$380. This engine will be N/A with Manley forged pistons, forged rods, stock crank, .020 over, and possibly TFS 38cc heads with a TFS Stage II cam for a CR somewhere in the neighborhood of 11.25:1 (according to the guy I talked to at MHS). Not absolutely sure he can afford the heads yet, but we'll see.
I called Fluidampr this morning and they no longer make a damper for this engine, part number 660202. They said it was never a big seller for them, so they discontinued it. I do like the idea of the Fluidampr better than the traditional design like the ATI damper, in that the Fluidampr should protect against harmonic vibrations over all RPM ranges, instead of being tuned to a specific RPM like traditional balancers are. There are still a few Fluidampr balancers out there, so I could pick one up for the same price.
Opinions on the pros and cons of each design?
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 10-17-2014, 10:43 AM
VTX1800N1
VTX1800N1's Avatar
Well, this may have been in vain. I contacted the seller on Amazon and it turns out he sold them on eBay and no longer has any inventory. Glad I asked. Still interested in which is a better design.
Old 10-17-2014, 11:28 AM
school boy
school boy's Avatar
The main question is what rpm limit will you be at?
school boy is offline
Old 10-17-2014, 01:20 PM
VTX1800N1
VTX1800N1's Avatar
For now, stock RPM limit. He doesn't have enough cash for an aftermarket intake plenum. That is much easier to change than the heads, and the original heads are trash because the cam bridge retainer bolts were loose and the cams walked, destroying the heads and bridge retainers (and the metal that went through the engine destroyed the rest of it). The stock intake stalls out at 6500 RPM for a stock displacement engine. He is bored .020 over, which adds 2 cubes. Combine that with the higher flowing TFS heads and it's not doing the stock intake any favors when it comes to upper RPM limit power. He may eventually go with a TF intake, but that is down the road a ways.
Old 10-18-2014, 09:44 AM
school boy
school boy's Avatar
You could go with a cobra balancer, they do well up to 7000 rpms. March and the new Steeda balancers do well too.
Old 10-19-2014, 05:41 PM
ESABATM
ESABATM's Avatar
The Mach 1 will also work well for this too.
ESABATM is offline
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
LivingInThePast
09-16-2015 12:20 PM
EASTIDEE123
09-14-2015 03:52 PM
whatsup62
08-29-2015 01:25 PM
Quick Reply: Help me choose a harmonic damper
