Help
Old 11-11-2014, 09:47 PM
mustangmark1988
mustangmark1988's Avatar
Default Help
I just received these parts in trade they are suppose to fit 1988 mustang, but the body he has seems roached, will these parts fit 2001 mustang gt?
p.s.s 306 short block-
Tremer 6 speed plus Pro 5.0 shifter-
p.s.s main girdle- gasket kit- 42 lb injector- Trick flow twisted wedge heads- Trick flow roller rocker 1.6- Trick flow intake- Trick flow valve cover- Trick flow under drive pulley- MSD billet distributor- MSD coil- MSD wires-Mobrisso oil pan- Forenza aluminum fly wheel -Mclead clutch-
Carbon fiber drive shaft- Turbonetics Turbo kit (turbo + west gate, blow off valve and header- Aluminum 4 core radiator- subframe connector- lowering springs 2.5"- Energy suspension motor mount-SVO rear end main girdle-
Ford motor sport custom tuned computer- slotted/brilled slug conversion rotor- polished stainless steel upper & lower control arms-BBK fuel regulator- BBK 75 mm throttle body-BBK egr adapter plate- pro- m 76 mm mass air-
Auto meter white /faced gauge's- 1988 Mustang Coupe body- clear tail lights/ 6 piece headlight kit-
mustangmark1988 is offline
