Transmission Switch
Transmission Switch
Hey, new to the scene to this forum so a little confused. But i was wandering if someone could help me out, i need to know if its possible to switch a 2000 GT Convertible from a Automatic to a Manual, or if i might as well get a newer one thats a Manual. Only reason im even considering the switch out because of what i have already done to my car would be a newsance to waste all the effort and switch everything out. Thanks
RE: Transmission Switch
i check with my mech for you,he said by all means ,cause they only got the one chassie design the knock outs are all ready there.he said in the long run youd be better off paying a ford tech to do it.man its going to cost ya big time.good luck hope this helps in your decision.post your out come im curious to know how you make out.
In the long run, you'll probably end up being faster with the automatic. Don't bother with the 5-speed swap, get a shift kit, and a big *** converter. Like 3800 + and that thing will come out of the hole like a raped ape.
I feel you though, I don't like automatic cars either, but faster is faster.
ORIGINAL: Sidewayz6.0
^^^^^ This is the best way to go. Do you have a hand held tuner? if so did you adjust the shift pressure/points? If not get one and adjust them you will really like how your trans feels then. If you want more have the j-mod done (or you can get a shift kit) and then adjust the line pressure with the j-mod and you will really love your car. I have the Trans-go shift kit and predator tuner and my car shifts really hard, but I love it.
ORIGINAL: Tim37
how doesn the computer react to a swap since the auto is run buy the ecu do ya have to swap it out or can you just buy pass all of that.
do all automatic transmission rely on new-fangled computers to shift, or are they still somewhat old school using the ATF in circuits to tell it when to engage a new set of clutches?
