Thermostat Housing help!!!
Old 01-18-2015, 06:03 PM
cominus
cominus's Avatar
Default Thermostat Housing help!!!
Well I got the right bolt off, im struggling with the left one, I know its a 10mm, I used a socket but it kind of stripped...how do I take it off, do I just take it to the dealership? I heared they had a special tool to remove bolts like that.
cominus is offline
Old 01-19-2015, 01:01 AM
dawson1112
dawson1112's Avatar
You can buy some sockets that are made for removing stripped bolt heads and nuts.
http://www.craftsman.com/shc/s/p_101...id=00952061000
Youll have to look for a set that has specific size for 10mm-3/8"
dawson1112 is offline
Old 01-19-2015, 09:50 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
take a 3/8s socket and tap it on with a hammer....
WhiteFoxGT is online now
Old 01-19-2015, 11:22 AM
school boy
school boy's Avatar
Op, both methods that whitefox and dawson mentioned works. I use the 3/8 socket trick when im in a bind, but be careful not to damage the plastic manifold. The sockets designed to remove stripped bolts work wonders and keep a set myself.
school boy is offline
Old 01-19-2015, 10:02 PM
cominus
cominus's Avatar
I bought a strip bolt set that have the metal pieces in the corners, they had another set but they looked like they were for removing the bolt permenetly. Hopefully it works tomorrow.
cominus is offline
Old 01-20-2015, 01:05 AM
dawson1112
dawson1112's Avatar
You don't plan on reusing that bolt do you? If it was me Id take it out and just go and buy a new one.
Old 01-20-2015, 06:38 AM
cominus
cominus's Avatar
I did just for the moment, where can I buy another one, the ford dealership?
cominus is offline
Old 01-20-2015, 07:17 AM
99GTvert
is my username.
99GTvert's Avatar
The dealer might have it but I would check at a local auto parts store to see if they have it in stock.
99GTvert is offline
Old 01-20-2015, 07:54 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I have some of those bolts. PM me a name and address I'll send you two
Old 01-20-2015, 07:55 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
If all else fails, they are simply 8x1.25 bolts, just find some the correct length
Quick Reply: Thermostat Housing help!!!
