Engine ID
Engine ID
So here's a question or rather a survey if you'd indulge me. The 8th digit is the engine ID. X is supposed to be Windsor and W is Romeo.
I'd like to know by VIN if anyone else has a Romeo with an X. For a quick reference go by the following.
Romeo=11 rocker cover bolts
Windsor= 13 or 14.
Doug
Windsor= 13 or 14.
Doug
Thanks for the reply. Mine is a Romeo with an X. From the few responses I've gotten on other sites, seems like regardless of whether you have an X that should indicate Windsor you may have a Romeo anyway which should be a W code. Apparently 96,7 & 8 could be MUTTS so to speak. Here is some interesting info on the subject if anyone cares to look through it.
Source:
http://www.therangerstation.com/Maga...0/Ford_4-6.htm
After doing some research it looks like the 99 to 00 Mustang got the Windsor's the 2001 to 2010 are all Romeo's. That's why the vin on a mustang is an X only indicating a 4.6L SOHC and doesn't indicate a specific plant.
Google Vin Decoder Fleet Ford.com
It's been a while but if I remember there was a fire in the Romeo plant in ny? And while they were rebuilding the 99-early 01 got the windsor motors.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
