gauge light issue
Old 02-27-2015, 09:53 AM
v8sn95
v8sn95's Avatar
Default gauge light issue
hey guys,
SO i know this has been talked about ALOT, so far i have read threads that go back to 2002...however, when people got information back then. they never came back and said if it worked or not. So here is my question.
My gauge lights work.....sometimes. when they are on they will flicker alittle. I read a thread where a guy hooked them up so when he hit a switch then they came on, instead of pulling the dimmer switch.
So i'm very inexperienced with electrical work, however, Is it possible to hook up the gauge lights to work off a switch / or hook them up so they stay on permanently.....
please detailed information would be helpful.....
thanks guys
v8sn95 is offline
Old 02-27-2015, 11:37 AM
Ldubfounded
Ldubfounded's Avatar
Changing the dimmer switch is super simple and same goes with changing the bulbs
https://video.search.yahoo.com/video...t=mozilla&tt=b
I would just replace all the bulbs while your in there and replace the dimmer switch.
Also dont forget to check your fuses, it could be a loose fuse (if its all the lights that are flickering.
Hope this helps bud
Ldubfounded is offline
Old 02-28-2015, 01:07 AM
v8sn95
v8sn95's Avatar
so its just the gauge lights....once again...driving home from work tonight...the headlights are on, and my gauges are OFF, however my check engine light (which is on due to needing to replace my thermostat)....any who, my "fuel, oil, tach, mph, and my other two are out...." my A/c in the center dash are still lit...
i guess i'm going to try to fix the dimmer switch and see if thats it....
v8sn95 is offline
Old 03-01-2015, 12:46 AM
sotom1
sotom1's Avatar
That video helped me. Thank you.
sotom1 is offline
Old 03-03-2015, 12:03 AM
v8sn95
v8sn95's Avatar
so i just got home from doing some work at the shop, i have come to the conclusion the issue with the gauges IS the dimmer switch, ordered a new one. it will arrive on friday and i'll install it on saturday. i'll let ya'll know how it turns out
v8sn95 is offline
Old 03-08-2015, 11:29 PM
xoHollieNicole
xoHollieNicole's Avatar
I put a new dimmer switch in mine and it fixed my problem!
xoHollieNicole is offline
Nick Oliver
10-17-2018 04:22 AM
mustangchef
09-04-2015 08:08 PM
raleigh05GTO
09-04-2015 07:09 AM
amandahchase
09-03-2015 10:09 AM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: gauge light issue
