High HP GT
High HP GT
hello guys, hope this is in the right section. I have a 03 gt 5spd. I would like to make it 700-750rwhp daily driver. it may go to the track every once in a blue moon. I have done some searching but would like input from yall.
I know it will need new internals; pistons, crank, rods, rings
cams for sure
want to do twin 66mm turbos
clutch
38-42# injectors
here are my questions, what would be good cams for f/I motor?
who makes the best internals?
what clutch would hold that power?
any good shops in the san Antonio texas area?
the car has a sct livewire tuner now, cai, bbk 78mm throttle body, cat back exhaust. clutch in it now seems real stiff, so it might already have clutch work done
are there any more weak points that I haven't read about?
cams for sure
clutch
38-42# injectors
You will most defiently need to upgrade the suspension. Sub frame connectors would be a great start along with lower and upper control arms etc.,. You'll also need a reallly good tire. Putting that much rwhp to the rear wheels will make driving almost impossible without good tires. I would also check your clutch. To hold that much power you'll most def need a high grade clutch. It's tons more stuff so Im preety sure some one will chime in.
I have doubts that there will be anything that remotely resembles "daily driver" with the power level you're proposing and all of the other changes/improvements that will be necessary to the car as a whole to get there, but if you have the money to do this then it will still be one hell of a car anyway. Good luck and keep us posted on your progress.
I want it reliable, so if it cost a couple thousand extra then fine to know I can make the power and it still hold together. that's what I mean by dd. something I can possibly detune to around 500-550rwhp and drive everyday and real quick turn the boost controller up to the 750ish range.
whats wrong with the uca's and lca's? I don't want to drop the car, it has some suspension done to it for road racing, seems a bit stiffer then a stock car which will all change as I want it softer in the rear to transfer weight. where can I get sub frame connectors?
tires are something im looking at but that's last on the list as it will be the cheapest. I don't want to tub it, but I will prob be on some 12-14wide proxis tires in the rear and prob 8wide in the front. I will get some beadlocks and slicks for if or when I take it to the track.
anyone have a place or 2 for the forged internals? the cast block seems to be able to hold that power and boost just fine. also do they make a 4v head that will bolt on?
well boys, I pulled the trigger on a modular motorsports long block 4.75stroker motor. 5199 was base price, I opted for a few extra goodies. total with injectors, intake, throttle body and fuel rails was right at 10k. should be here in about 3 months. they are 6weeks behind and about 4 weeks till they have they manley rods in. here is the motor if anyone is interested
MMR Street Mod 1000SE 4.75 Liter Stroker 2V Longblock (up to 1000 RWHP) (fits all 96-2004 Mustang GT)
This Fully forged MMR longblock can handle up to 1000HP. They include the
MMR Street Mod 1000SE shortblock with Forged MMR/Manley Pistons, 4340
Forged MANLEY H-Beam Rods w/ARP bolts, Forged Crankshaft fully balanced
and blueprinted in a Brand new Ford Racing Cast Iron Block, and fully
assembled with new Ford Motorsport PI heads, ARP head studs, MMR/Felpro
head gaskets, New factory Ford Motorsport Valves, springs, retainers,
lifters, roller followers with factory PI cams professionally
timed/degreed with new timing chains,guides, tensioners and a High
Volume oil pump.
1 year warranty
Just add your Valve covers, oil pan and timing cover and GO!
Options:
Upgrade to MMR Hurricane Billet oil pump gears $289 (includes lifetime warranty on pump)
UPGRADE TO TRICK FLOW HEADS +$1499
Upgrade to BOSS 302 Iron block (will produce 5.0 Liters) + $1199.99
Upgrade to New Alloy Block $1299
Upgrade to Stroker 1000S shortblock (Produces 5.0 Liters or 5.3 with BOSS 302 Block)+ $400
Upgrade to MMR Street/Racing Oil pump +$99
Upgrade to Stage 1 Ported Heads +$800pr
Upgrade to Stage 2 Ported Heads +$900pr
Upgrade to Stage 3 Ported Heads +$1100pr
Upgrade to Stainless steel Valves +$275
Upgrade to High Lift Valve springs +$239
Add ARP Main Studs +$169
Upgrade to Stage 1-3 Camshafts +$599
Add MMR 7qrt Street/Racing Oil Pan +$229
Upgrade to ARP 2000 Rod bolts +$99
Extended Warranty (extends warranty to a total of 18 months) $500
Volume oil pump.
1 year warranty
Options:
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
