25 mm spacers installed......help
Hey guys,
I just installed 25mm spacers on the rear of my sn95. It pushed it 1 inch further away from the hub, the problem i have now it that it rubs if i hit a pothole or drive on uneven pavement, or even transition from higher to lower pavement and vice-versa.
Granted the shocks and struts, are probably stock....anyway to determine if they are stock or aftermarket.....(serial numbers, codes, impression on the shock?)
Also I thought maybe i could cut away at the rear fenderliner, however i realized our car doesnt have them.....
any suggestions would be appreciated.
http://www.americanmuscle.com/blackb...9904-stag.html
i just bought a set of wheels with the correct width and back spacing. problem solved.
