Speedo Cluster
Old 04-01-2015, 12:47 PM
donaldg
donaldg's Avatar
Default Speedo Cluster
I have a 98 gt and the odamater, trip meter work fine. But my speedometer sticks and if i tap the glass it works right. It does that all the time. Is it the gears in the cluster? I found gear kits but do they include gears for speedometer? Please help!
donaldg is offline
Old 04-02-2015, 06:35 AM
dhavi4226
dhavi4226's Avatar
The gears you found are for the odometer. The speedo and Tach are electronic.
dhavi4226 is offline
Old 04-11-2015, 09:48 PM
petrock
petrock's Avatar
As dhavi4226 pointed out, the gears you found are for the odometer. The speedometer & tachometer are electronic. The electric motor that actuates the speedometer is likely going bad. It happens. They get a flat spot and sometimes stick. If you can’t find one at your local autocrats store or online I’d hit up a junk yard and scavenge one from a recked car. Good luck...
petrock is offline
5.0muscle
01-11-2016 01:17 PM
andrew1969
16
01-08-2016 02:48 PM
67LimeCoupe
11-25-2015 08:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Mr. D
Tuner Central
08-27-2015 05:01 AM
Quick Reply: Speedo Cluster
