Pretty major problem with tierod
Old 05-25-2015, 02:50 PM
cgibbons51
cgibbons51's Avatar
Default Pretty major problem with tierod
Hi guys I have a pretty bad popping sound coming from the inner tie rod so replacing it sounds good but its also leaking a lot of power steering fluid right inside the boot and the boot is cut open from the previous owner. So what would be the best idea. I heard of a seal replacement kit for like $60 and tie rod for like $30 and then a boot for another amount in the end replacing the whole rack and piston would be used for $170 or so. Unless there's an easier seal type thing to do I'm not sure. Its a 1997 Mustang GT
cgibbons51 is offline
Old 05-26-2015, 05:10 PM
VTX1800N1
VTX1800N1's Avatar
Get a new/rebuilt steering rack from Rock Auto. They come with inner tie rod ends and are easy to change on a Mustang.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 05-27-2015, 02:14 PM
cgibbons51
cgibbons51's Avatar
Bought a Duralast one from auto zone not sure if that was a good brand but let's hope it works good and lasts. My tie rod is dead gone been riding with a lot of popping and vibrating at high speeds
Old 05-28-2015, 02:42 PM
cgibbons51
cgibbons51's Avatar
Wound up I replaced the rack and pinion because the tie rod was loose and leaking power steering. So the popping didn't go away and the vibrating is still there
Old 05-28-2015, 07:51 PM
VTX1800N1
VTX1800N1's Avatar
A bad tie rod won't cause the rack to leak. The seals in the rack were bad. Check all your other suspension parts. Rotate the wheels front to back to see if the vibration follows. Check the lower steering shaft u joints and rag joint for excessive wear or play. Is the vibration experienced only while braking, accelerating, or all the time?
Old 05-28-2015, 09:04 PM
cgibbons51
cgibbons51's Avatar
Braking causing huge vibration in steering wheel. High speeds passenger side tire vibrates. Also while turning right the passenger side pops just like before my new rack and pinion
Old 05-29-2015, 07:37 AM
VTX1800N1
VTX1800N1's Avatar
Popping sound is probably ball joint in the control arm or outer tie rod if you haven't replaced it. Could also be the upper strut mount. Vibration in the steering wheel while braking is warped brake rotors. Replace them.
Old 05-30-2015, 02:52 PM
the4thgen
the4thgen's Avatar
Nice im having the same problem now and just found that power steering was leaking from the bellow only drivers side and when i turn wheel to the right....im just gonna duct tape it lol....i wish but really was not sure on what to replace and after reading this it sound like its will have to be the rack thx
the4thgen is offline
Tivo304
08-28-2023 12:19 PM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-03-2015 08:43 PM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Pretty major problem with tierod
