wont go in gear, need help
Old 05-26-2015, 03:30 PM
drag1320
drag1320's Avatar
Default wont go in gear, need help
i have had my 2000 mustang gt 5speed for only a month. when i got it, it worked fine. now it wont go into gear when motor is on but shifts fine when off. now sometimes it will work fine then stop letting me back in any gear and will grind if i try to go in reverse. i got a new cable already
thank
drag1320 is offline
Old 05-26-2015, 04:41 PM
Chromeshadow
Chromeshadow's Avatar
Sounds like the clutch is the prob, was it having problems before replacing the cable? There is an adjustment procedure for the cable.
Chromeshadow is offline
Old 05-26-2015, 06:39 PM
drag1320
drag1320's Avatar
It has a newer clutch , and had the problem so I go an adjustable cable thinking it would fix it.
drag1320 is offline
Old 05-26-2015, 09:20 PM
jwog666
jwog666's Avatar
did u check your quadrant? its the part the cable attaches to at the clutch pedal, the factory one is plastic and prone to breaking
jwog666 is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: wont go in gear, need help
