How much oil for a 2001 GT?
Old 07-29-2015, 08:50 PM
TwoSixSided
TwoSixSided's Avatar
Default How much oil for a 2001 GT?
Hello, I just did an oil change on my 01 GT with a blower on it and I'm having an extremely hard time finding out if I added the right amount of oil. I put in 5.5 quarts. Every thread I have looked at seems to be completely divided. Some people use 5 some use 6 some use 6.5, etc.
I don't want my engine to be hurt, did I add too much? The dipstick is useless. Even with 5 quarts the stupid thing reads over the full line.
TwoSixSided is offline
Old 07-29-2015, 09:45 PM
98BlacknWhite
98BlacknWhite's Avatar
5 quarts is definitely low. If you didn't change the filter, 5.5 is good. If you changed the filter, do 6. Do you want to be safe anyway? Do 6 quarts.
EDIT: I just reread you had a blower on it. It doesn't change things "too much", but just be safe at 6 quarts. Many will say they run fine with 5.5, but if you aren't penny pinching or want to be safe then do 6.
98BlacknWhite is offline
Old 07-30-2015, 11:51 AM
Z28KLR
Z28KLR's Avatar
6 qts to fill.
The original factory fill recommendation was 5 qts and then revised and made retroactive to include the '96 - '01 m.y.'s in 2002. For 2002 and the revised recommendation there were no changes made to the engine beyond a new dipstick that reads "full" at 6 qts instead of 5.
Although in theory it would make sense to run an additional 1/2 qt (beyond the 6 you should already have in there) or so to accomodate for the blower, I'm entirely unsure if that would be necessary, and with a stock pan it may even be potentially harmful should capacity be exceeded there and cause oil foaming due to the crank dipping into the oil.
Z28KLR is offline
Old 07-30-2015, 12:07 PM
Camster
Camster's Avatar
My 04 owner's manual says six total,and that brings it exactly to "full",with the filter changed at every oil change.
Camster is offline
Old 08-06-2015, 08:49 PM
01moostanggt
01moostanggt's Avatar
Does anyone have the part number for 6qt dip stick?
01moostanggt is offline
69MustangCoupe393cid
10-03-2015 10:33 AM
Sixer4Life
09-29-2015 07:03 PM
wraith777
09-28-2015 10:49 AM
Sixer4Life
09-28-2015 07:05 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: How much oil for a 2001 GT?
