My 5.4 4 valve Swap begins... 2002 GT
Old 09-27-2015, 07:48 PM
  #31
Gary Ugarek
Gary Ugarek's Avatar
So here is where things stand:
As you know there was a stoppage due to this little fella coming in 10 days early. Meet the newest Member of the Mustang fan club, Jackson.
As far as the build, this is where it stopped:
Gary Ugarek is offline
Old 09-28-2015, 04:57 PM
  #32
Gary Ugarek
I need to extend the wiring for this piece so I can connect it.
I bought the adapters to go from Stock GT injectors to my EV6 injectors
Old 09-28-2015, 06:28 PM
  #33
uberstang1
Chupacabra
uberstang1's Avatar
extending wires isn't really a big issue, its good you got the adapters, is there anything wirring issues u can't figure out?
uberstang1 is offline
Old 09-28-2015, 06:33 PM
  #34
Gary Ugarek
How the wiring goes for the battery terminal posts and junction box.
I can't seem to find the negative terminal... I don't know if he removed it and tossed it somewhere or if he forgot to return it.
Old 10-05-2015, 01:44 AM
  #35
Gary Ugarek
Ok, so I have the wiring to the junction/relay box figured out. Finished bolting up the sub frame brace today. Installed the Cobra Oil Cooler kit, Had to cease work in PLenum/top hat. The stock IAC valve will not work on the Sullivan intake with the water crossover, so I had order the IAC from a cobra to clear it. I am also trying to find an applicable throttle cable. The stock GT/Cobra cables are too short. And lastly I am now I am fighting with Alternator placement.
I got the bracket from Sullivan and purchased a 6.8L Diesel Alt, swapped the pulley but have to fight it mounting it Problem is, if you mount the bracket first, you don't have the room to fit the bolts into the alternator (Side rail and wiring harness in the way).
So I may have to look at fabricating a reverse mount system and use the original alternator
Anyone know of any places with a reverse mount kit for SN95's or am I fabricating.
Old 10-06-2015, 03:36 PM
  #36
WJL
WJL's Avatar
Congrdulation on the new one, hey i'm sure you already did but make sure you have a ground strap on that motor since you are talking wiring. Looks like that will be a lot fun to drive.
WJL is offline
Old 10-07-2015, 07:37 PM
  #37
uberstang1
Chupacabra
uberstang1's Avatar
Not sure on the alternator, but congrats on the little guy, I got one coming in march.
Old 10-12-2015, 06:56 AM
  #38
uberstang1
Chupacabra
uberstang1's Avatar
Gary if u know anyone I'm selling the motor out of my car forged 4v with intake and IMRC deletes
Old 10-12-2015, 07:33 PM
  #39
Gary Ugarek
How Much do you want for it? PM me, I can put the word out.
Congrats on your soon to be coming little guy.
Oh and BTW, I got it to turn over today. WOOHOO!!!!
Just need to run a few vacuum lines and reset the fuel system.
Old 10-13-2015, 08:46 AM
  #40
uberstang1
Chupacabra
uberstang1's Avatar
Taking reasonable offers at this point.
Quick Reply: My 5.4 4 valve Swap begins... 2002 GT
