Trouble with the motor
Old 11-25-2015, 11:07 AM
Crawford55
Crawford55's Avatar
Default Trouble with the motor
Hello, I have just a standard 2004 mustang, 40th anniversary edition, and out of no where it has started giving me problems. I was driving one say and them all the sudde . It's like she was struggling to go. It will crank and everything, but it won't go over around 2 or 2.5 RPMS it just runs really high when you try to. Any advice? I want to take it to the shop but I would like to try and see how much money I'm looking at before I have to have it towed there, to have it turn around and have to get towed back. Thanks!
Crawford55 is offline
Old 11-25-2015, 12:41 PM
Z28KLR
Z28KLR's Avatar
Check engine light on or flashing?
Could be a lot of things.... Ignition issue (bad plugs or coil), fuel (plugged/restricted filter or dirty injector), catalytic convertor gone bad, MAF sensor issue, vacuum line broken/disconnected.... We could go on and on.
If the CEL is on, get the codes read and then post what you came up with. If you are mechanically inclined even just a little bit then get under the hood and start looking around. This is likely to be something simple if you have a general idea of what to look for.
Z28KLR is offline
Old 11-26-2015, 06:47 PM
Seabee1993
Seabee1993's Avatar
What Z28 killer said, there's a plethora of things that could be interpreted if you could see if any codes are being thrown first.
Seabee1993 is offline
Old 12-07-2015, 06:58 AM
tadpole1969
tadpole1969's Avatar
sounds like might be a transmission issue
tadpole1969 is offline
svfetter
10-05-2015 11:39 AM
FivePointToTheOh
09-29-2015 12:53 PM
wishinsky
09-21-2015 09:48 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
09-10-2015 11:46 AM
Quick Reply: Trouble with the motor
